Thefarmboy21
Ok so after sitting for 10 years, I've finally got my 87 back on the road again. Sitting that long is ******* anything and mine is no different. I'm trying to just drive it around local and work all the bugs out before I decide how much I'm gonna sink into it.
The electronics do not function correctly. The gauges don't work right at all I don't think. Sometimes they don't move and sometimes they do. The temp gauge never moves up hardly at all, the tachometer takes spells wen it does or doesn't (reads 200rpm at idle when it works, is that right?) as does the speedo. When I am in reverse the speedo actually goes backwards past 0 until its hits the peg. And the oil pressure gauge always either reads nothing or very very low, But I have and aftermarket gauge that tells me it runs between 25 and 50. The voltmeter seems to actually work and read correctly but I have no idea if it is truly accurate or not. And my engine light does work because anytime the oil psi drops to zero on the factory gauge it kicks on. And the fuel gauges jumps around and reads full until it gets down to about 1/2 tank I think. BUT I havent used the rear tank yet.
SOOO.....the big question, How do I fix it??? New senders, clean senders, new gauges? I don't really care much about any of it besides the temp and speedo, but I'd like the tach to work correctly too. BTW Im pretty sure I know where I can get a cluster if I need it. Called a guy parting out a 91 350 and I'm goin to attemp to buy the rolling chassis after he gets what he wants from it. He said what's left of the cab on the frame and axles for $300 I think. BUT you can't count on this guy :/ Thanks guys, this forum has been a great help so far.
