metalminded
95 f350 powerstroke
I didn't notice exactly when it happened but at some point i looked down and the tach was dead. then i noticed that the volt gauge and the light on the shifter indicating OD on/off was also dead.
is the OD light tired to the tach?
I looked over some fuses before it got dark out and everything i looked at was ok.
Maybe a loose plug on the cluster? bad ground?
just trying to pick up some ideas here for diagnosis.
truck seemed to run fine I could not cycle the OD on or off but i got home ok.
thanks in advance
side question. (bonus points)
My last truck, a 97 powerstroke, the cluster lit up when you turned on the headlights. on this truck you have to click the bed light on for the cluster to illuminate. what might cause this?
thanks in advance
