Fuel water separator
Fordman75
Lonsdale, MN
Napaonline specs here: FILTER
Also for a primary filter you would use a higher micron rating like a 12 then your secondary would be your stock filter, whether its 12 (7.3) or 6 (6.9) micron. This way the primary catches the bigger stuff then the secondary stock will catch the rest. This gives you longer intervals instead of plugging up a super fine 2 micron filter all the time.
My plans are to mount a Facet Dura-Lift pump under the hood. I'm going to mount a Goldenrod water separator filter ( 15 micron ) before the pump and then some kind of finer filter after the pump.
87crewdually
Southern Nj.
If your fuel level was higher than the point of where you cut the line, it caused a siphon. If you blew air in the line towards the tank, the siphon would of stopped. Glad to hear it all worked out for you though.
IDIBronco86
