fuel tank gauge
greythorn3
wheelordie.com
alaska
:hail Hello im new here my name is ray, i was comming in to ask if anyone knows what color the sending unit wire is from the front tank of a 6.9 86 diesel as somone has hacked mine to bitz and i would like to see if my gauge works..also what color is the wire to the gas selector switch for the gauge. they threw the rear tank in the trash so i got a selector with only one tank and its a front tank...
thanks ray
Diesel JD
Gainesville, FL
I may have teh schematic...if I find it I'll post what I find, but if memory serves...you ahve a blue/yellow wire which is the wire for your front fuel gauge, a brown white which powers the gauges on teh dashboard, and 2 wires, control the selector valve. It works by reversing polarity to pin 1&2 on the harness. The back tank gauge sender wire is yellow/light blue, and if you poke around underneath the truck, you'll find that the first two wires I can't remember if its the outside 2 or inside 2 but when you plug in your voltmeter it will be the one that has +12V key on in the front tank position and -12V in the rear tank...or I may have that backwards, but either way, the 2 wires will have 12V at all times when the key is hot, the polarity controls which tank is used. In all likelihood the selector valve quit working or teh rear tank rusted out and the Po wanted to deep six it and keep driving till he could dump the truck. A new selector valve is $90.00 and a new tank is about $120 for stocl steel or a lot more for a plastic or oversized tank. You could also try contacting ARGVE, he taught me everything I know about this system and still knows it very well even though he went over to the dodge side.
J.D.
Bosoldier
Batavia, NY
FSV, fuel gauge... All appearantly Dead!
Greetings, All,
I'm a noob here and to the diesel powered ownership world too. Anyhow, I have an 88 E-350, 7.3 non turbo and I too am having my share of troubles with the dual tanks and their general function. I have been told one tank pumps fuel to the other when switched and told that is incorrect, etc.
I just want to sit down with a true understanding of the function, some good schematics and fix my van right!
These forums and the combined knowledge that's contained within just blows my mind! You folks are Great! Thanks
Any help will be appreciated
Michael Fowler
Bel Air, MD
Slight hijack here...
I had to replace the fuel sending unit/ electric pump in a company F150. It came with a schematic to correctly wire it up as Ford had replaced several different parts with a single replacement unit. The only difference was the wiring to the old harness. In the 2 months that elapsed before I could install the part, some "cleaning up" around the office threw out the schematic. Can anyone supply the jumper schematic for this part?
Thanks.
RangerDanger
