fuel tank advice
One thing I`ll add, when I got the tank it was coated in a light oil to keep it from rusting.
I washed it off with Wax and grease remover.
This stuff, I order it on line and pick it up at O`Really`s.
https://www.amazon.com/Kleanstrip-P...ocphy=9030905&hvtargid=pla-569618139042&psc=1
Clean it off good and then scrub down with that LA Awsome from the $ store.
Then treat it with Phosphoric Acid, and POR it. Sprayed it with that rubber bed coating.
Ford used some canvas impregnated tar strips between the tank and straps. I also painted the straps, then put a thick coating of RTV on the tank and on the straps as a cushion.
This tank will never rust.
I originally thought about the sump, but I don`t have 1000hp under the hood so don`t need a 1/2" supply line. My tired old 100HP 6.9 does ok with sucking it from the top.
I have also seen supply lines going under a larger truck being pulled loose and creating a huge mess.
Farmer Rock
Glen Rock,PA
I originally thought about the sump, but I don`t have 1000hp under the hood so don`t need a 1/2" supply line. My tired of 100HP 6,9 does ok with sucking it from the top.
The main reason I want the sump is for the easy access and simplicity. This will be a daily/work truck, so the most it's gonna get is a turbo in the future, but nothing crazy. I was planning on priming the tank before install and then use the POR15 or fluid film when I do the entire undercarriage of the truck. I was thinking of making a guard around the sump, and the supply lines will be tucked away.
Rock
CBRF3
Southern Illinois
Thank you, I am hopefully going to order the parts tonight, so I will definitely look at LMC.
Rock
look up a bronco fuel tank gasoline version our sending unit fits directly into it and filler neck also
https://www.amazon.com/Spectra-Prem...allon+tank&qid=1615939994&s=automotive&sr=1-1
https://ecat.spectrapremium.com/products/F8D
as for the sending unit that is easily modified to work
as for a fuel sump kit these work pretty good the square section in bottom of our tank is a perfect fit for it pretty straight forward install
https://www.amazon.com/AirDog-Cummi...fuel+sump&qid=1615939454&s=automotive&sr=1-23
if your tank straps are rough here you go
https://www.amazon.com/dp/B000C7TZM0/ref=au_as_r?_encoding=UTF8&Make=Ford|54&Model=F-350|669&Year=1988|1988&ie=UTF8&vehicleId=1&vehicleType=automotive
Farmer Rock
Glen Rock,PA
https://www.amazon.com/Dorman-576-2...+fuel+tank&qid=1615939294&s=automotive&sr=1-2
I haven't gotten around to ordering the parts yet, which may be a good thing since I wasn't sure. how hard is it to make the bronco tank work? I am on the fence about the bronco tank or the F26E tank. I am definitely going to look into the bronco tank, thank you for the link! My main concern is the sending unit, but if I can modify one from a 19 gallon tank, that is fine.
Rock
CBRF3
Southern Illinois
Rock
I re edited my post I messaged you the tank comes with all the hardware needed to convert it for under $100 only thing really need to modify is the sending unit stem length
The dorman one i linked was for a older truck i put a large isuzu diesel in I didnt realize till after i linked it forgot all about it but looked up proper one and re edited the post with correct one.
Farmer Rock
Glen Rock,PA
I just got your pm. I was actually clicking on the original link when I got your message, so I didn't notice it Lol. I really appreciate the links, they are exactly what I needed. That seems like a very good price for that.
Rock
You shouldn't have to. I used the factory tank in my Bronco. Other than a plugged (inline) fuel filter early on, I didn't have any issues.
Farmer Rock
Glen Rock,PA
Ok great! Thank you.
I am really looking forward to getting this started.
Rock
Just remember that I was using a tank that had been used for gasoline for years. With a new tank, you shouldn't have any issues at all.
I have a brand new F8B tank waiting to go under the back of my Blue Truck. I haven't messed with dropping the original one yet so I can't confirm or deny the sending units swapping over. It's on my LONG list of things to do. It sucks just using one tank on longer drives.
