timothyr1014
okay, my IP is leaking, pulled the line going from the middle of it to the filter, rubber seal is just fell apart. so here come the questions...
1. Do all of the lines have these rubber seals, and where can they be purchased (they appear signifigantly thicker than just an o-ring)?
2. I have not pulled the IP totally out yet.I have read not to pull the gear cover however my manual says I need to, and I cannot get to the bolt on the lower passanger side that holds the pump to the gear...what am I missing?
3. Am I correct in my assumption that if I have an injector line leaking at the pump (as in a solid river of fuel) it will have the same effect as the line being open at the injector itself, hence the injector not firing (all of my other symptoms fall into the catagory of bad injector, but I cant see paying to get them tested until I know they are getting the fuel they need to operate)?
Looking forward to some help
Timothy
Timothy
