spencnaz
- Joined
- Jul 26, 2006
- Posts
- 314
- Reaction score
- 0
The UV dye will come in two forms, one for the cooling system and another for fuel systems.
Awww MAN! You're killin' me here!i had one do this.dont know what it was,never tore the engine apart to find out.just replaced it.it ran perfect no over heating or anything,just dumping fuel into the cooling system.
Good info. I didn't know since I've (obviously) never tried using it for anything. Is it very expensive?The UV dye will come in two forms, one for the cooling system and another for fuel systems.
well,im not sure how long it was doing it.i do know that last august we needed the truck to work the demo derby to drag cars out of the track.it was my buddies truck.it had a coolant leak that i later found was a freeze plug.well we filled it with block sealer so we could use it.halfway into the 25 mile trip the freeze plug popped out.i was told just drive it and get it to the fair.so me and another buddy drove it atleast another 5 miles till it wouldnt run anymore.we towed it back to the shop,replaced the freeze plug so it could be used as a yard dog.well then my buddy decided to replace the cab.as i drained the coolant it has black gritty stuf and clear oily substance floating in it.i figured the black stuff was soot and the oily substance was fuel as the cooling system and coolant wreaked of diesel and exhaust.the truck ran perfect though with no problems to show it had a cooling system problem.we used the truck from august last year till sometime in january this year when i ripped the cab off of it.
Thanks man. It doesn't solve my problem, but that info at least makes me feel a lot less anxious about the situation and my inability to do anything major to address it immediately.yup you read it right
since it was running fine it was being used on the road daily till january when i started the cab swap.
my best guess would be a lot of fuel in the coolant.i drained it after it was driven so most of it wouldve been mixed together as it had about 30 minutes for it to cool down and seperate before i drained it.
Since I don't have a UV light, what do you think of the MMO idea instead?
Did you have anything floating on top of the water in the neck of the radiator? If so, what color was it? What color was the cloudiness? Any smell?
I would think that if it was from engine oil you'd have been seeing droplets of oil on the water, that the droplets would be black, the cloudiness would be kind of milky white, and there wouldn't be much of a smell. Is that what you saw?
What I'm seeing is droplets of very thin greenish-yellow oily stuff floating on top of the water, the cloudiness in the water is more the color of tea with a little creamer in it, and it has a strong fuel/solvent smell......
Would it be possible to have a crack in the head and a fuel injector leaking in its bore?
I'd say that'd be a long shot, plus it seems he'd be getting misfires and low compression in that cylinder if that were the case.
Haven't drained any, but I pulling the dipstick while its running (so everything in the crank-case is all mixed up good) and checked it. No diesel smell to the oil - just smells like used oil.Cheaper Jeeper, can you drain out a little bit of oil, does it smell like diesel? When was the last time you had an oil analysis done?
