fuel filter bs!
chris142
SoCal
You didnt strip the threads. You just been turning it the wrong way for 2 days.napa has a big thick filter wrench made just for our trucks and it takes a 1\2 breaker bar
Poway, CA
I used an old leather belt around mine after I saw a video on youtube showing this trick. Worked for me, but I still had to CRANK on the thing.
Mike
1466IH
waterloo, il
I have had to wrap a 2in ratchet strap around a piece of 1&1/4" square stock and then turn with a 24" crescent on big equipment filters before
(Basically made my own heavy duty strap wrench)
yARIC008
Drives really slow
Orlando, FL
I really don't think you ruined the threads. If you did it would be off by now, lol.
Kinda like in Jaws... I think you're going to need a bigger wrench... You can buy a ultra large set of channel locks from Northern Tool.
mohavewolfpup
Diesel Wolf Puppy
Las Vegas Nevada
Pliers yanked it off. Broke the bleed valve, drilled out and rethreaded. Brass screw and threadlocker. Hope it holds. Nothing in a junkyard except a ***** 7.3 SD and later model crew cab, engine gone
Vincent
