pignoble
I recently installed all new injectors and a Conestoga IP, and the truck has been running great. I'm in Houston and ventured out this morning to check on a friend's house as he's been on vacation and wasn't here for the storm. Had to drive through some water, but not deep - no deeper than a foot, probably. On the way back, the truck surged and stalled on me twice, but I made it home. I haven't had much time to troubleshoot, but I have determined that no fuel is getting pumped from the tanks, regardless of which tank the selector switch is on. This was verified by disconnecting the feed line on the in-line filter where the previous owner removed the water separator.
I have been planning to drop both tanks in order to clean them, check the pickups (truck only takes 7-8 gallons in either tank), and fix the painfully slow filling problem. Now that the need to get the tanks sorted out is pressing, I've been reading about the senders here and on other forums. I keep seeing JC Whitney universal senders referenced but I can't find any actual write-ups, and the part number I've found isn't working. Is it still possible to get universal senders to replace the stock units? Can I use non-diesel senders from the '86 year, if not?
