FS: Lots of IDI parts and 80-86 ford parts
Dogbrain
Virginia
I have lots of IDI parts from various projects. Two disassembled 7.3 IDIs. One 6.9 IDI that had a lot of work done and then stripped the timing gears. Also have two single wheel rears, one 10.25 one dana 60. Also two T18 transmissions with transfer cases. Make me an offer on any or all.
theguruat12
Certified Tinkerer
Albuquerque, New Mexico
I need the water-in-fuel light module from the engine wiring harness. The wire that comes off the WIF sensor in the fuel bowl should run right to a little black box (solid state relay). Or I might be willing to just take the whole 7.3 engine wiring harness depending on how much you want for it....
Dogbrain
Virginia
Don't think I have water in fuel item, may have a vac pump, have 2 sets good 7.3 heads.
JSVD
Juneau, AK
if he doesn't have the injector lines PM typ4... he told me he had some recently
KyleQ
Minnesota
I'm after a T18 bellhousing so I can bolt it up to a broken ZF5 so I can have the bell welded up and fixed. Any idea on price?
placidoert
