F350farmboy
The Hornet
I have a mostly complete '90 7.3 IDI in the shop taking up too much space....it needs to go.
Whats available:
-Block *unknown condition, but ran when disassembled*
-Heads complete with valves & springs...I'm keeping the rockers, lifters, and push rods.
-Complete set of valve cover bolts/nuts and keepers
-Intake manifold with all hardware.
-Exhaust manifolds with all hardware *One broken ear tab, broken when I got it, but is included.
-Main caps and hardware
-Coolant necks
-Front and rear engine covers
-IP and camshaft gears
-IP gear housing with hardware
-Ford reman. water pump with "V" style pulley
-Both motor mounts and hardware
-Camshaft *Grooved fuel pump lobe, nice for electric fuel pump mod if it won't work with a normal pump*
-Crankshaft *Has been sitting on its side for almost a year, Don't know if it has done any damage that way*
-*7* pistons and ALL connecting rods, pins, caps, oil jets, and hardware
-CDR valve *Holds pressure when I blow on one end while blocking the other end*
-Harmonic balancer
-Might be other stuff I forgot...I'll look over everything when I go take pics of the block/heads/cam/crank/etc.
I'll get pics later as photobucket wont let me download any pics today
MAKE ME AN OFFER for any piece!!! or take everything for $100. I'm only going to have these up for sale for a few weeks, then I'll keep what I might want and scrap the rest...like I said, its all apart and takes up too much room.
I could deliver to short distance as long as you have a way to unload it off the truck.
Whats available:
-Coolant necks
-Harmonic balancer
