Front sway bar mounting
bike-maker
albany, OR
Been searching the web for an hour and came up with nothing so....
Where does the front sway bar bolt up on the trucks with the tall / narrow radiator?
My truck was originally a gasser, and the original sway bar bolted to an additional cross member that sat directly in the way of the transplanted diesel core support - so I unbolted it and scrapped it.
Pics would be much appreciated.
cpdenton
Truck needs paint.
Conway AR
I could get you a picture of a 2wd 92 model...
wh1056
Julian, PA
This is what is/was on my 1990 F350 diesel 4X4.
The sway bar mounts on the back side of the axle:
These are the frame brackets for the end links:
They mount on the inside of the frame rail behind the main crossmember.
Close to where the arrow points:
bike-maker
albany, OR
Thanks guys - exactly what I needed to know.
The versions shown above are different than the ones I found on the internet and what was originally on my truck.
Unfortunately for me, none of the 3 versions will work for my application....
Radiator support, intercooler, and front axle are going to make me head in a different direction.
