gatorman21218
So nearly 300,000 miles later, my front end is about wore out. And all those years with the PO pushing snow didnt help things either.
So it seems my options are this: rebuild the Dana 50 or swap in a dana 60.
now I dont think the 50 is a bad axle. after all its had a good run. but then again if the 60 is SOOOO much better, then ill swap it. however after my hydroboost install, I heavily favor the rebuild option.
So I need opinions from those who have rebuilt the 50 and who have swapped the 60. And I assume I should rebuild the 60 before I swap it anyhow.
