Hydro-idi
Gary, I plan on doing that tomorrow.
Driver side cylinders looking cleaner than the passenger side.
Woops.....I wiped the drivers side clean before taking pics. That's why it is like that.
That one head could have been milled flat once before, so having it done again, even if it's within spec, might have gotten cut down just enough. That coupled with the .030 aftermarket pistons that may be .00x taller than factory could contribute to your valves smacking the pistons. ALWAYS measure. One of the reasons why I prefer inline sixers. Milling on block/head doesn't have to be done at an angle in relation to the next angle. All flat
Sorry to hear that.
As I recall the same shop that did the short block also checked your heads???
Before the new block was put into service.
If this is the case.....
I measured protrusion using some feeler gauges and a straightedge on top of the piston at TDC. Could the cam gear be off a tooth?
