Well without getting into significant details of project other than it's part of Brown Bruin build, it appears I'm going to be doing some cut/join/weld/sectioning of a frame or two.
Now I will start off with # 1 point
I DO NOT HAUL HEAVY...
Truck will be running ton running gear for certain, leaf springs to start.
Just some basic measurements show me I'm OK to cut the two frames and join them together.
Ex cab front section / Bronco rear section. Not 100% on this but wow...looks like a perfect marriage to me![sly :sly :sly](/styles/default/xenforo/smilies/sly.gif)
I"m ok with doing my cuts, and making all the joints match, tacking them together and also some supports too keep things straight. I'll get some fish plating done too to keep it all safe/strong
I'm not OK doing the finish welds what so ever those will be done professionally and I'll have the cut/joint section boxed on the inside and more as well.
Here is my quandary, and what I want to know is; has anyone here done a frame sectioning? If so was it to shorten or lengthen the frame? How did you do your cut? was it a Z cut on the frame sections and fit to match, long angular cut what?
I've decided to get this grey truck done and run it as is so to speak, and do all my supercab body work and prep work that frame. I've also considered cutting the back off the cab and sectioning my Bronco's rear portion on so I can have my dreamed of supercab Bronco. Thus the joining of the two frames.
BIG project, going to be calling on some favors for sure and asking for new ones!
Bottom line I just want to hear about how you have successfully sectioned a frame!!!!
Thanks
Al
![yell :yell: :yell:](/styles/default/xenforo/smilies/yell.gif)
Thanks
Al
