frank-id
Today was truck lite day. I have made a strip with some relays to control the head lites. I decided to check the lamps and sockets. That was a real experience. One head lite body could not be removed as the up and down adjustment was frozen in place. The socket required is a 4MM of reasonable quality. The other lamp was not installed properly and the socket was partly melted. The lamp housing was removed and the lamp was made to fit. The adjusters were made to work easily with anti seize and WD40. The wiring is not yet complete and a couple driving lites are mounted on the front bumper. The lamp housings are almost $100 each side.
Anyone know of a method of cleaning or polishing the lamp housing front? Are there better thsn factory bulbs? Frank in Idaho
