Ford 4 cyl industrial engine
Diesel_brad
Dunce
gilbert pa
This is in an old Leroi compressor. It used to run 5 years ago. After messing w it for about a half hour while charging battery i tried to turn it over by the fan:rotflmao. Well that didnt work , so i put a braker bar on the crank bolt. NOPE, Seized-cuss. Then the oil was over full, noticed water on the tip of the dip stick. Cracked drain plug and i get coolant, I figure at least 2 quarts.:eek:
So it would make since to me that the block is cracked, pistons are seized, so i need and engine. Anyone have a clue where i could find one? I checked craigslist and ebay but nothin
Or has anyone evre run a air compressor w an 8N? off the PTO
smokin69
Always smokin'
Baraboo, Wisconsin
Not an air compressor, but I know it's possible. I've seen auxilliary hydraulic pumps run off the PTO's. On my grandpa's wood splitter we run a PTO hydraulic pump for it. I've run it on our 3400 with no problem(bout the same size as an 8n). As long as it's the right RPM don't see why you couldn't.
sassyrel
iowa
if you could find a place that used to deal with, or still does with industrial engines--they could tell you what base ENGINE that is, and you maybe could find a block out of something else--and switch the externals--could have been used in a tractor--i know they also used them in a lot of ag machines.swathers,mowers,corn detasslers,et al.
Dsl_Dog_Treat
Decatur,MI
Could fab up a 3 pt mount and drive shaft for the 8N.;Sweet
Send it on up and I tell ya how it works.:D
Diesel_brad
Dunce
gilbert pa
i just relized. My 8N is not enough Hp. the 4cyl that is in the compressor is close to 50 My 8n is only 23
Dsl_Dog_Treat
Decatur,MI
Here's a thought.
Some of the old Clark forklifts ran a Continental 4 cylinder engine. I'm sure there may be a good source of power plants for ya that way.
Or snag an old Perkins.
Diesel_brad
Dunce
gilbert pa
I borrowed my boss' compresor to do what i need to get done on this job. His is the exact same compressor but it has the continental engine. His works great except for the broken ring. It burns a gallon of oil an hour:eek:
Diesel_brad
Dunce
gilbert pa
i tried to buy it off of him sinc he dont use it, then i could fix his and have mine for parts, but he dont want to sell:dunno
Garbage_Mechan
Garbage Mechanic
Central Cal Foothills
If it is a pushrod 4 cyl overhead valve it is a 172 or 192. The were used in the late 50' early 60's tractors like the NAA and Jubilee. They were sold as industrial engines at least thru the early 70's probly longer. They are bullitproof and cheap to fix.
Diesel_brad
Dunce
gilbert pa
actually it could be a 134 172 or a 192. I have a an engine manual for them, I just dont know which one of the 3 it is
sassyrel
iowa
thanks,didnt rem which!!!! but have seen them in a lot of diff ag machines. believe gehl also used it in two models of the skidsteers, and not all that long ago.
typ4
Newberg,OR
All the ones I did at evergreen were not cheap to fix. If the crank is bad, toss the engine and find something else. Used ones are a grand from engine parts suppliers.
Put a 302 in it, lots of leroi's had them in.
Nanohawk
