if you're serious, I will.calvin, grab it up. bring it with ya to the rally!!!!!!! i will buy it off ya!
Man I wish this could made to work with an automatics and do it well. I'd have a brownie in a heartbeat. Those gear vendors are just too rich for my blood.
There's a few guys who have installed teh things behind slushboxes. THey just use them as a range selector like a transfer case ( need to be stopped or near stopped to change ranges,) but it gives you a whole different combination in each gear. If you are really good at shifting without a clutch you could shift while moving while hooked up to a slushbox
On this box in particular how would I determine my actual final drive ratio if I had a 4.10 rear end and the brownie was in overdrive?
At one time I calculated out most all the brownie and rear end ration combinations, but , I've slept since then and can't remember how the heck to do it, but I think gear vendors has the formula on their website.
Thx I'll check it out! Do you know what the overdrive gear on this is? .84?
