Follow the Thunder Pickle
93f250idi
strokin
cadiz ky
going with past tense, as you aren't on line... How did it handle 7,ooo feet above sea level, and 60? mr I'm gonna boost it tot he moon... 60mph? Really?
All jesting aside.. good luck on yer journey.
with 4:10s and 35's he's prolly turning some rpms at 60. :dunno
Clydesdale
Nampa,Id
4.10's and 35's equal stock tires and 3.73's. so not horrid rpm's. 37's make 3.54, which was 2700 at 70.. still a little high for my taste.
93f250idi
strokin
cadiz ky
taller tire, less rpm's.
Redneck OverDrive.
well i put some smaller tires on my f250 it has 3:55s and it feels higher geared. maybe its all in my head i went from 265/75/16 to 215/85/16. im planning on getting some 305/75/16 i think thats about a 33"?
Clydesdale
Nampa,Id
never seen that size, have seen 305/70, and that is a 34.
quick math on tire size. take 305 divide it by 25 (real number is slightly higher) then take the sidewall dealy, the 75 or 85 and double it, so you are 1 and a half, or 1.7.. multiply the divided by result (in this case 12) with the 1.X (in this case half) and add that to rim size. in this case its `18+16=34. Your new sneaks are 34" tall and 12" wide.
Diesel JD
Gainesville, FL
4.10s and a C6 it's a screamer unless you have some huge tires on there or some sort of OD. I had that with 265/75/16 back when I was seeing a girl down in S. FL, I don't envy him a cross country trip in that setup. 3.55 and T18 is a screamer enough but nothing like 68mph at 3000 rpm on the FL turnpike!
Clydesdale
Nampa,Id
thats why I have mine geared down to 2350 at 80... in 4th. :D
Dieselcrawler
Professional wrench holder
Quakertown Pa
hrrm..... he is in the middle of a field next to elephant butte park not moving....... hrrm.....
think he made a left at albuquerque?
Abull78
More boost Mr. Scot
Nevada
Its the shake down perriod. Had a few things creep up, nuts and bolts looseniing, oil cap, cdr line. Thinks she is all worked out, been runnin75 today
Abull78
More boost Mr. Scot
Nevada
2500rpm 67mph, 3000rpm 75mph. I've been averaging 17mpg with th ac on.
I see we are stopped now in Texas. I looked at the map by opening it up more to see whats up ahaed. Why is there so many I40 markers on the map so close together just after armarillo...:dunno
mydixiewrecked
