First Oil change
camoman
What are guys using for a drain pan? gotta find somthing to hold that much oil..
secound Q is how much oil exactly should it take?
adrianspeeder
USAF C-17 Avionics
Dover AFB / Harrisburg PA
Harbor freight had a big pan a while back, but ran out before I could get one. I have one of those Blitz units with the spout and lid, but had to cut a bigger hole in the top so the large volume doesn't swamp the little stock opening.
Adrianspeeder
rigdog43
Cureo TX
wife's big roaster pan, she can't find works well ;Really shhhhhh don't tell er.
ever wonder why men stay in hot water :backoff
oh ya dead dinosauers , thats what i use , change often . ( clean oil, clean fuel, clean air ;Sweet )
Saftman
Get a Fumoto Valve, put a hose on it (about 5' long) and drain to a 5 gallon plastic gas can. Works every time. :thumbsup:
TNF250
Coopertown, TN
Saftman said:
Get a Fumoto Valve, :thumbsup:
I use the Fumoto Valve with the nipple. I drain the oil into the 1 gallon oil containers from the last oil change. With the valve you can stop the oil in between gallons.
Bear Hunter
RLTW!
I'm with the last two posters....get a fumoto with the nipple and drain into your old containers.
olsen726
