Also don't let it scare you too much. I've heard of engines with great blackstone reports committing suicide not long after and then a lot of folks like me have had consistently sketchy reports and still running strong. That WVO is bad news especially if: You're truck is driven only relatively short distances and not worked very hard. WVO is a lot less combustible than diesel or B100 so low EGTs= poor burn, injector and ring coking, washing down the rings....bad bad bad. Or if, your wvo is high in FFA, by high I mean anything beyond say a 1-2 NaOH titration, even that is 1.4-2.8% FFA by weight roughly. If there's one good thing that has come out of the environmental movement and getting the sulfur out of our fuel from the engine's perspective it has to be less sulfur to react with combustion products= less H2SO4 in the crankcase to attack the bearings. WVO introduces another acid albeit a much weaker one, into the crankcase. It's conjecture on my part so I need to look into it some more, I just have seen some scary reports with WVO engines, and after experimenting with small amounts of wvo and seeing my lead jump from 9ppm to 103 in one change I said nope, I'm done with this. One more thing, 5300 miles is a lot to put on dino oil unless you have a bypass filter. 3 quarts of make up oil and it isn't terrible though.
