Filters, oil, and service manual recommendations
TangTonic
St. Croix, USVI
While I wait for my IDI to get here, I want to stock up on some fuel and oil filters. I don't have a manual yet so could someone please tell me the part numbers for these and which brands are recommended. Also, what oil should I be adding when I change the engine oil? The truck is a 1994 IDI Turbo at 98,000 miles. What maintenance items should I begin addressing after oil change and fuel filter change? I will be checking the SCA levels. Also, what manuals should I buy? I have found a 1993 Ford Econoline seires 7.3L IDI manual on Ebay:
http://cgi.ebay.com/ebaymotors/1994...Motors_Manuals_Literature&hash=item53e855ba90
And a turbo supplement:
http://cgi.ebay.com/ebaymotors/1993...Motors_Manuals_Literature&hash=item5d2f7eca59
And I also found another manual on ford-trucks in pdf format called 93 94 7.3 Turbocharged Diesel Engine. Would the two listed above be recommended to buy? Any others that would be better?
Thanks for the help.
'94IDITurbo7.3
HAMMER DOWN!
Fowlerville Michigan
Yes get the turbo supplement. the first one is just the little manual that comes with the truck. that one is up to you. the PDF manual that you found has some good info on it.
Here is the powertrain manual that i want.....
http://www.bgcollectiblesplus.com/servlet/the-231/1993-Ford-F250-Super/Detail
Here is the Chassis/electrical manual that i want....
http://www.bgcollectiblesplus.com/servlet/the-3012/1993-Ford-F250-Super/Detail
I use valvoline heavy duty diesel 15W-40. you can use the oil filter for 1995 PSD.
'94IDITurbo7.3
HAMMER DOWN!
Oil Filters
  • Fram Extra Guard - PH3766
  • Mobile 1 Ext. Performance - MI-402
  • Motorcraft - FL784 ('95 PSD=FL1995)
  • Purolator Classic - L30288
  • Purolator Pure One - PL30288
  • STP - 3766
Fuel Filters
  • AZ Filters - FF816
  • AC Delco - TP1251
  • Purolator - F54692
  • Motorcraft - ???
Air Filters
  • STP - AF 322
  • Purolator Classic - A44853
  • Car Quest - 88317
For oil just use any reputable 15W-40 diesel oil.
Check our tech article "the parts bin" for many of these items. Helm was the producer of the original shop manuals, so you may want to know that name for your ebay searches.
ntjapkes
