fault code p-2146
69dieselfreak
well that nice
rimrock arizona
this is my brothers truck 03 dodge cummins 6spd
started to act up on him acting like a clogged fuel filter anyway he pulled this code P2146 Fuel Injector Group 1 Supply Voltage Circuit
can you guys give me a hand in trying to diagnose this problem
thanks guys
fidoinlv
las vegas nv 89108
04dodge cummins auto trans
Whit
lost in Why-homing
I dought it helps but change the fuel filter and see what it does..................also clear the code and see if it comes back
69dieselfreak
well that nice
rimrock arizona
as far as i know it only happens when my brother turns his chip on but when he is in the stock setting its fine thats all i was able to come up with
MMeier
Las Vegas
Sounds like a faulty box/chip issue. Send it in to Edge and have them take a look at it. Make sure there are good clean connections everywhere, one bent pin can cause all kinds of grief.
69dieselfreak
well that nice
rimrock arizona
id agree now i just need to look at the truck for my brother
but ill tell him that but thats what i was figuring but not really shure though
rigrunner
Bainville/Mt
My 06 did the same thing, would run rough. When I let it sit for a day it would run fine for a few miles then start missing again. had same code, but when I took it to the dealer they couldn't find the problem untill they finally replaced the injectors and no trouble since.
720Diesel
