Extra Filters
BRONCO
Geno,
Have you ever ran a vacum/pressure test to see if all of those filters are impeading your system?
Geno
Noble Ok
Bronco
Sorry for the late post but I have a bypass valve and I adjusted it to less than a 1/2 lb at wide open throttle. Engine seems to run smoother but probably my imagination. The lift pump is actuated with a oil press switch. Have never found air at the bleeder valve on the Mega.
Geno
Lance
