I've got two IDI's, a 90 and 92. Pic below towing the 92 from S. Carolina to Ohio thru NC,VA,WV and OH. Some pretty good hill's in WV, no trouble with an automatic tranny, don't remember ever shifting down, course I had the trailer brakes to compensate for more braking. Now my 99 SD that I towed a 5er 15,000 miles to Alaska and back, came back down I-15 to Yuma AZ then to Ohio, hit some pretty good hill's in Montana and Utah. I do have the TC lockup on it and that helped a lot on downhill braking. Lost my trailer brakes, due to gravel breaking the trailer brake wires, thank God for the TC lockup on a 9% down grade, the engine was screaming at 3600 RPM and 75 MPH, only a couple of curves, kind of slid around those on the brown stuff in my pant's. Burned up the pads and rotor's on that one. When I had my GM bus 4107 24K lbs. I was cautioned by other owner's to NOT let up on the braking down hill, that allowed air (Oxygen) to replenish on the brake lining's causing them to get HOT, just down shift and keep a slight braking on. Worked for me.
This is where I replaced the pads and rotors in the rain.
