Ever seen this?
needlenose
Irrelevant Data
The pulley is broken off the bearing hub and is just spinning... kinda. The compressor spins smooth. My wife must have been driving when it happened, because I never heard or felt a thing. She's been driving it all over the place like that with no A/C.
cpdenton
Truck needs paint.
Conway AR
Sure have!
We have a ranger that did this. On mine, the compressor locked up though. I was driving it about 35 MPh through town when it happened. Funniest part....this truck has a full airbag suspension system and lays the frame on the ground, thus, it has no inner fenders. When the pulley let go, I watched it bounce across traffic!
Good luck with the fix.
Chris
ToughOldFord
The Cold Glow-Plug
City of Shasta Lake, Ca.
It's just the front half of the clutch that let go. You need to find out of it did it due to age and wear or if it's because the compressor seized. If the former you can replace the clutch and be good to go.
You are missing the portion of the magnetic clutch that is activated to engage the compressor for AC.
It will spin all day when AC is turned off just as you are experiencing now, and then BAM the clutch crabs when electricity is applied and causes it to actuate the compressor.
JM2CW
chris142
SoCal
all the time.all you need is the outer hub,a shim and a bolt
Its as posted s far. The part thats missing is the part that connected to the pump drive shaft. When power is applied to the coil it magnetizes this piece and sucks it into the part you see causing the pump shaft to spin. They have a free spinning air gap too. If its too much gap the flex steel will have a difficult time being pulled in to the electromagnetic clutch part. Its an easy repair or find a good ac shop and allow them to do it right and get a warranty too. Care must be taken to make sure the pump is not gone bad and locked up or turns ruff. Then a pump replacement is in order and flushing the system because of pump parts getting in the condenser.
Surprisingly, I've actually seen a ton of those a long the road. Mainly near stop signs/lights.
Sent from my SM-G900R4 using Tapatalk
needlenose
Irrelevant Data
Yep, the bearing locked momentarily and it snapped the pulley loose from the hub. It's been riding on the magnet for the last 2 weeks. The only thing holding it on was the clutch plate.
Wonder if I can get a few more miles out of that magnet??? Just kidding. :)
needlenose
Irrelevant Data
JM2CW
Sorry, I just realized I was unclear. I removed the clutch plate, it didn't come off on it's own.
Well thats a good pic of what went wrong. You can buy those bearings and pulleys with the clutch ready to go most better auto parts stores or ac shops. You will need a puller installer tool to remove the bearing race from the pump body.
lewisstevey7
