gatorman21218
Mechanical gauge puts hot coolant thru your firewall and into the cab with you. Great if they never leak or break. If they do (and they can) burst/leak, you now have very hot and toxic fluid spewing into you cab. I've seen it enough times to only run electrical gauges for coolant temp, fuel pressure, and oil pressure. Sure you can buy an "isolator" for them, but that adds significant cost and another point for failure.
Heath
Heath your wrong about this. A mechanical pressure gauge requires oil or fuel or air or whatever to be plumbed into the gauge. So yes I have copper tubing full of oil and fuel in my cab.
HOWEVER. A mechanical Temp gauge is different. It is a one piece unit that includes a probe, bushing, line and gauge. the unit is totally enclosed and filled with the same stuff that is in that thermometer that is hanging on your grandma's kitchen window sill. In fact it is like a giant 12 foot long thermometer. Except there are no markings on the tube, but a gauge at the end. As the probe heats up, the liquid stuff expands, and the needle moves. No coolant is used in the gauge. So if the engine was running and you cut the tubing, no coolant would spill.
The only way coolant could ever get in your cab is if the probe got a hole in it AND the tubing broke. Highly unlikely. Its completely safe to use. Also very accurate. Just dont kink the tubing when you install it.
http://www.autometer.com/tech_faq_answer.aspx?sid=1&qid=4
read this it explains it better than me.
As far as installing a mech temp gauge, the hardest part is finding the hole to put it in. once you find it, all you have to do is mount the gauge and screw in the probe. there is NO wiring involved, unless you have a backlight for the gauge. All that needs is to run the hot wire to the acc panal and plug it into a fuse (forget which one) and then ground the ground. or you can just run the hot wire from the hot side of the solenoid and put a toggle switch somewhere.
