gdhillon
My engine temp idiot light just came on today after a couple minutes of driving so I pulled into the closest parking lot and shut her down. I checked the oil it was right above the fill mark (but i assume some oil was in the engine still). Then checked the overflow thats fine still at the cold mark (it never really fluctuates in level). Lastly i checked for leaks and didn't see anything. So then i fired her back up (with heat fully on mix) and about a minute of driving the light came back on so i just slowly made my way home. I checked my manual it doesnt specifically say "engine temp light" so i looked in the engine overheating section. Possible causes are leaking coolantsystem or oil cooler system or defective coolant recovery system, slipping or damaged belt, thermostat stuck closed or leaking head gasket. What it tells me to check is; adjust or replace belt as necessary ( i just put a new one on with the new idler and new tensioner ). Check and replace if necessary the thermostat and head gasket.
My thoughts are the thermostat but i do get warm air when I turn the heater on.
Maybe I should replace the hose going from the rad to the overflo...it does seem a little hard
I dont think its the head gasket or oil cooler (no oil in coolant...i resealed the oil cooler last year)
O and the temp gauge on the truck was still pretty close to cold.....Any1 have any other input on this?
