My Oil Temp. sensor is in the Trans mounting flange drivers side. The temp indicated is right after the oil cooler suppling the oil galleries, who cares what the oil pan temp is, it means nothing. The oil after oil cooler is what helps cool the engine and what is supplied to the bearings. Pulling a 33 ft 5er yesterday, weight was GCW 20,690, oil temp was 190 - 200 @ 55 MPH, trans temp (4R100) was 210. This was my 99 PSD, but it's still a 7.3L, and that was running with Max AC on. Don't have a coolant sensor but the fan clutch would kick in about every 4 miles, that indicates the coolant temp reached 240.
