Would like to see what other use for a funnel for the 45 degree engine oil fill. The best funnel I have found is 1 quart oil bottle with the bottom cut off. Is there a fancy funnel that will thread in?
Me too. It works best. I've used a long transmission funnel. It doesn't work really well when the oil is cold. In an emergengy, I've even rolled some paper up into a funnel shape and used that. Whatever it takes!
