9779scott
93 Banks turbo, new trk to me.
I bought the trk about a month ago and always thought it was short on power. I turned the pump up 2 flats and that helped alot. Today it started to galop on start up like the IP is going out. Here is where I get confused though. When I make a rolling turn about 3/4 of the way around the corner the truck comes alive and breaks the tires loose on wet road then after I straighten out all the extra power is gone. Is this because the truck is starving for fuel until you go around a corner or is it getting a shot of air in the line? It started doing this at 3/4 of a tank so I filled up and it still does it so that should eliminate a pin hole in the pick up tube. I can blow air threw the line. Also if I switch to the back tank the truck dies after about 20 seconds, but it has done this since I got it and have not had time to diagnos that. So bad; IP, lift pump, lines, pick up in the tank. I also so the previous owner scabed in rubber fuel lines to the tanks.
