larryo here again. anymore info on how to properly use the fox valley 160. have this one and don't need info on the ferret set up. just need to verify the info from my last reply ,thanks.anyone?
Hi and welcome to the forum, most likely won't be much help but I"ve got an idea to maybe assist you.
advanced search
TECH 101 in search field, choose thread title
riotwarrior in username field
look for thread about timing tape.
You will see that you can time BEFORE or AFTER TDC with just a non adjustable timing light if you have to just with that thread.
So long as the timing light has a reading and provides a pulse you can determine where that pulse is in relation to 0 degree mark on the timing tab.
With this info you should be able to get your setup to function.
This is simply why we suggest the pulse method as it registers BTDC and IIRC that adapter though more expensive works well with adjustable lights.
My method described has been confirmed by me with use of my Kent Moore J33300 meter and a normal timing light and also an adjustable light as well.
If I had a lumi probe setup I'd do some testing and see if I can find out a method that works and do a tech 101 on it
