LCAM-01XA
Oookay, here's an update on the whole situation:
1) I first did SigEpBlue's mod with the 100-ohm resistor jumped between the main power supply and the low pressure EPC solenoid wire (white/yellow) - resistor was installed last night, today I didn't notice no changes in transmission behavior whatsoever. So tonight after work I decided to measure the voltages at the wires with the truck idling in gear (truck driven against a tall curb with a big stone wall just a few inches away from the bumper) - as expected the red wire had 13.xx volts (batter voltage), however the white/yellow only had 9V at it. Aight, now let's try without the jumper - shut truck off, pull resistor, restart truck, and sure enough white/yellow wire now reads 8.3 to 8.5V - so the jumper not only didn't lower the voltage, but like Mr. Roboto suggested it actually increased it, by 0.5V to be exact. Which if anything would result in a slightly softer (and slower) shift - not what I want.
2) Time for Marq's mod - pull SigEpBlue's jumper completely, cut white/yellow wire, attach bullet connectors to both loose ends (so I can plug it back together and go back to a stock circuit), then attach bullet connectors to the spare 100-ohm resistor I had (Radio Shack sells them in packs of two), and finally plug the new resistor between the two ends of the white/yellow wire. Take truck out for a drive - wow, what a huge difference, clutch engagement is very fast, shifts are not neck-snapping but still very firm, maybe a bit firmer than I'd like them to be. So tomorrow I'm gonna go to the Radio Shack again and grab a pair of 50-ohm resistors, and set one of them up as a replacement for the 100-ohm unit I got now - that should soften the shifts a bit, but still be far from stock. One thing I noticed tho, transmission seems to run hot, not like I ever touched the pan before really. Shouldn't be much of an issue, I got two coolers up front, plumbed in series - I know for a stacked-plate coolers tis good to plumb them in parallel, but those are snake-tubes so to the transmission fluid they ain't nothing more than a looong transmission line.
Jumper and consequently inline resistor were installed in the harness halfway between the driver-side frame rail and the transmission, as in that spot the wires are very easily accessible. Once I decide which resistor I wanna use the connections will get coated with dielectric grease, and then nicely taped up and covered with corrugated wire loom.
Questions, suggestions, concerns?
