FIRM SHIFT
I wanted to wait to do it first before telling everyone about it, but I am confident it will work. I may have to modify something after I do it but here it goes:
Our E4OD pressure lines are controlled by two (2) solenoids; a low ECP (Electronic Control Pressure) solenoid, which connects via pin 11 on the transmission connector; and a high ECP solenoid, via pin 12. These two (2) pin (wires) are the last two (2) wires on the outside of the connector toward the front of the truck. There are two (2) rows, inside (close to the transmission), and outside (away from the transmission). Pin 1 (is the first pin/wire on the inside towards the front of the truck, and will be a solid red wire (provide 12 volts to the transmission)) Pin six (6) is the last wire on the inside towards the back of truck. Pin seven (7) is the last pin (wire) on the outside towards the back of the truck. As a side note, pin four (4) is the wire that controls the torque converter lock up.
Any, the ECU sends 12 volts to the high ECP (pin/wire 12, last wire on the outside towards the front of truck), and sends 12 volts to the low ECP (pin/wire 11, next to 12). As long as the voltage is the same regardless of the voltage (in some applications, and condition the voltage will be less than 12 volts), the line pressure will be at whatever pressure you are feeling now. Here is the trick, by limiting the voltage to the Low ECP pin/wire 11, the pressure will increase (beings as you cannot increase the High ECP, because it will be at it's max valtage). Now, the less voltage to the Low ECP, the greating the line pressure, the firmer the shift. Now, there are several things you can do, such as use resisters, etc., but; All I am going to do is wire a potemeter (like a volume knob), which when you turn it, it will cut the voltage (basically it is a rotating variable resister). I will just cut the white with yellow stripe wire at pin 11 (see above), and attach wires to extend them (the white/yellow wire that goes now to the pin 11 on the transmission, and the white /yellow wire that runs back to the ECU) so I can mount my knob on the dash. Now, just drive, and turn the knob till it shifts where you want it, mark it, and smile.
Marq
