! E4OD light blinking, and jerking on takeoff !
snaponprofile
NY
Yep, exact wheel base.:D The guy wanted 650 for everything including pedals and TC.
I wonder what I can get him down to without those.
snaponprofile
NY
I am looking at thia today, just thoutof something, will a S5-42 handle the power i am putting out? Why do most guys want the S5-47??
Prolly nothing wrong with the E4OD tranny. With the trouble you had/have, it went into limp mode intermittently. The tach and speedo have to be working flawlessly. Just about everyday there is a post about the E4OD, most of the time the tach sensor or VSS is the problem. Without fixing the problem it will destroy it. In limp mode you only have 2nd and reverse.
snaponprofile
NY
Boy am I happy, I got a ZF5, single mass flywheel, clutch, crossmember, slave cylinder, hard line, neutral safety switch harness, stick, rubber boot, and driveshafts.
Guess how much???(Hint:it was a good deal)
Rep to correct guesser.:D:D
lewisstevey7
