E4OD electric gremlins
okie
oklahoma
'93 N/A E4OD. Bought the truck and thought the trans valve body needed rebuilt and speedo didn't work. New vss really improved trans but hard 1-2 shift and bump in and out of OD over 65mph. Also speedo erratic over 50mph. 2nd vss same problem. Week later tach guage at 0 until engine warm up, only on really cold mornings. Another week tach at 0 permanently and trans in limp. Replaced tach sensor same problem. Anyone with fresh ideas appreciated, thanks
gnathv
Athens, Al
If trans is in limp mode you should be able to pull codes to find problem.
okie
oklahoma
I tried pulling codes with a jumper but got nothing so today bought an innova OBD 1 reader and got no codes, NO ALL CLEAR CODE, couldn't even get a link indicator on it even jumping to battery ground
gnathv
Athens, Al
Sorry wrong year, 94 cigarette lighter and obd power port are same fuse. Doesn’t apply to 93.
okie
oklahoma
1 checked all fuses early on
2 no check engine light ever, may be burned out
3 ran and drove nice for few months except for bouncing speedo and occasional OD off flash
4 then one day tach stayed at 0 and trans was in limp, permanent OD off
5 Pulled gauge cluster and the circuit paper looked awful, tiny spots of rust all over under side; didn't take cluster apart to see condition of boards. Plugged it back and speedo and gas gauge didn't work for a while then came back but speedo still erratic
okie
oklahoma
was thinking it was the gauge cluster; probably speed issue for a long time and now tach gauge finally went too. It looks bad enough on back it could be issue and lot of guys on here fixed same trans issues with psom replacement. But I also can't get codes out of tcu/ecu/pcu/ecc whatever you want to call it
gnathv
Athens, Al
I’d start by trying to get tach working and see if that leads you to the problem.
For your transmission to work you need signals from the VSS, Tach, and FIPL.
okie
oklahoma
replaced vss first; got speedometer off 0 but flutters after 40
replaced vss again same problem
replaced tach sensor after tach gauge went to zero; no change
gnathv
Athens, Al
Follow your tach or VSS signal and see where it stops, could be dash, that’s where they intersect.
gnathv
Athens, Al
Have you pulled out instrument cluster and cleaned all connections and grounds?
gnathv
Athens, Al
Being your not able to read codes, have you checked your TECA relay? This powers the TECA (Transmission Electronic Control Assembly) module.
Pin 1 has voltage all the time. When you turn key to start or run Pins 37, 40, 57, and 60 are powered also. It may be worth checking.
Vincent
