If I remember correctly, there was something quite a while back, I think at TDS, about how LED's did not draw enough amps to trigger the TCM into knowing whether or not the brake was on. However, I have always been led to believe that the signal reicieved from the BOO switch to the TCM was just a 12v trigger. The 74 code is telling you that the BOO switch, the Brake On-Off switch, is not properly working. It is located atop the brake pedal under the dash. It will have two wires coming from it. Trigger wire is a light green wire going to pin 2 of the TCM.
