Cowboy_Customs
Rhinestone Cowboy
I noticed this a few weeks ago but thought maybe it was cause it was acctually cold for the time this fall up here. (like 32*) I had 2000 pounds in tow, and this is the only time it happens.
Loaded with around 2K+ in tow, from a stand still, only in first gear till around 1800-2000 RPM's then smooth.
I just went to MD-DE this weekend with about 4-5K in tow, and same thing, starting from a stop, 1st gear till about 2000RPM.
It isnt bad by anymeans, but noticible. Fluid looks good, smells good, proper level when warm.
I did find this thread but wanted to check and see if I need to follow the same process for my symptoms. http://www.oilburners.net/forums/showthread.php?t=12736&highlight=shudder
I did notice on this trip I have some speedo wobble, not much, maybe 2-3 MPH on either side. Thanks!
Oh, no blinking OD lights or anything, no hard shifts, just nothing out of the ordinary, only the symptom i described above. The tach does work smoothly.
