88 Ford
Its coming along man. You are getting to the home stretch now. It'll be worth it when you get to drive it! Can't wait to see it run bro!!!
Cleaning up the threads in the block when using studs is not really that important but its still something that should be done. Screwing a stud into a hole thats not clean down to the bottom thread wont change the torque on the stud because the torque is from the top fine threads winding down on the stud. Also its from the friction between the nut, washer and head so antisieze must be applied to all twisting and turning locations. Sometimes when a nut is tightened the washer under it turns with the nut and creates friction. So lube it all neatly. You will get a good torque that way..
