It's too tall for practicle hauling anyway.![]()
huh? i tow all the time with mine and i think mine is taller with bigger tires
subscribed, as i was thinking on the dt360 for mine.
That's what I may have to do. That's how its been done before....see below:
HERE is a video of the above truck in action!
Heath
Do you already have the Dt?
Yep, from my first post in this thread...........see above.Well, the 1st step is done. I've purchased an 1993 DT466C.
The DT360 is only a 1/2 inch longer than the 5.9 Cummins and is much easier to fit under the hood than the 466. But, I really wanted the DT466 because you can get more HP for less cash, with more reliability, and with more torque per HP.subscribed, as i was thinking on the dt360 for mine.
It's funny you posted that. I talked with Brent at Gene's Machine Shop today. He also recommended the Dana 80 for the same reasons you mentioned. He thinks I'd be OK with the Dana 60 up front if I don't try and pull with the truck. But for your standard 4x4 use, it should be fine. As far as the T-case, he thinks a built NP205 would work as well. But, that seems a bit worrisome to me.There are a lot of people that have equivilated the rockwell deuce.5 axle to being weaker than a D70. This information is on Pirate4x4. The thing you gain with the rockwells is like you say driveline angle.
Without doing any research on your situation I think you would be better off starting with D80 axles. I believe a lot of Dodge 1 tons run D80's stock. These come factory with 1410 spicer drive lines.
With the Dana axle setup you could run many different gear combinations. I believe this would really help with the drivability of your rig.
Paul
Thanks for that info Steve. That would be a big help. I'll have to have a look for one of those medium duty Fords. It would certainly save some fab work.Take a look at a medium duty diesel of the same body style(F750). Check out the "dog house" that bolts to the center of the fire wall. It will let you move the motor back. This will also take some weight off the front axle. Couple of ways to go with this. Get the dog house and dash out of a medium duty and swap it into your cab or swap cabs for the complete medium duty cab.
Steve
I didn t know that the 466 could make that much power..I wonder how hard would it be to swap into my ih 1600
without looking at anything, I'd think that if you could get the motor down low enough so that you could notch the firewall and not effect the dash board that'd be the way to go. Maybe the stacked frame deal would allow you to mount the motor below and the body of the truck on top?
I'm just thinking that this probably won't ever see a 3rd passenger so you could lose the middle seat position, but you probably don't want to have to completely reconfigure the dash board to fit around the new firewall. (unless you don't want heat and a/c ducts)
Oh and you'll probably want an automatic trans since the shifter for a manual would be way back--maybe.
