DT360 build
Maybe an appropriately angled spacer will allow proper clearance
thats doable. but i quite enjoy making things like that. time will tell.
gonna get that pontiac out of the garage tomorrow and get the front cover, oil pump , pick up and pan on, and maybe make a run stand.
i lack casters.
  • Like
Reactions: Clb
Clb
Another old truck
nannyfornia
i lack casters.[/QUOTE]
Ummm
Houston????
"i lack casters"
Gunna need to strike yer sig line there bud....;Poke
New intake sounds fun tho...
Carry On
i lack casters.
Ummm
Houston????
"i lack casters"
Carry On[/QUOTE]
casters. to make that roll around engine stand, moveable with 1100 pounds on it
Clb
Another old truck
nannyfornia
:Thumbs Up
Gunna need a ponny engine and geardrive to motivate the loaded eng run stand around.:cheers:
Good to see the poncho moving forward
front cover finally sealed, oil pump on, water pump done, tomorrow i gotta cut the engine mount so i can get the back cover on, then, a stand.
bottom end all buttoned up.
got everything to make a run stand.
flywheel and starter are ready to go on.
gotta get this thing off the engine stand so i can finish up the oil cooler and filter mounts.
if anyone has a DT360 2 piece water pump pulley, im in the market.
and shes ready to finish!
i bought a 3 groove, this can go back on the dt466
also bought a oil regulator waiting on that so i can mock up the oil system and cooler.
needs a turbo return, and oil filters to finish the oil system.
t-stat hose, filter, and inlet adapter to finish the cooling system.
i need to hook up a can of diesel, and again, a filter to complete the fuel.
time pump, adjust rocker arms, install flywheel and starter.
cant wait to hear this run.
subway
be nice to the admin :D
York PA
Looking awesome! Glad to see another build, I never cracked my engine open for my swap.
big things coming! including another round for the 87 6 door, it needs a bit of lift.
i still dont have an intended use for this. YET.
but hope to get it running soon.
HarleyCummins
