DT Series engines
EricW
my $h!t is stuff
Middleton, ID
With all the posts I've been seeing of the DT swaps, I'm curious as to what all they came in...
runaway!
Wisconsin
You mean where the motors originally came from? Older dump trucks and larger tractors mainly.
FordGuy100
Silverton, OR
Buses, medium duty trucks of all sorts (international) and sizes. That would be the most common.
smokin69
Always smokin'
Baraboo, Wisconsin
Larger vehicles from International.Pretty much most of there medium duty trucks, bigger tractors(1086 and stuff like that) and buses like said before. One thing on the tractors, there IP's would need a different governor to make it road worthy.
Sycostang67
Scooty Puff Junior
Kuna, ID
I was always excited when the isuzu diesel(TC 3.9) at work would break down or need service. We would rent a Freightliner with a DT466 with a 5spd and air brakes to replace it.
funnyman06
Coventry, RI
Did you find the DT, faster then the isuzu? I know every tow truck drive ill talked to prefers the little mitsu FUSOs to the big DT466. They say it sucks gas and is slow compared to the FUSO.
Sycostang67
Scooty Puff Junior
Kuna, ID
The isuzu had a lot more pep, it had a 5spd as well. I just prefered the louder rattle/size/power of the DT motor and the hiss of air brakes. :D
I'm sure they are conservatively set to give a very long service life. Those little chinese engines probably will not last as long. Considering that you can get an extra 100 HP out of a DT just by turning up the pump and doing nothing else, sort of hints that they are sleeping giants.
hesutton
The Anti-Anderson
Bowling Green, KY
Mel, you should see the size of the main caps!:love: The DT466 is wonderfully over built.
Heath
smokin69
Always smokin'
Baraboo, Wisconsin
Considering that the DT466's in pulling tractors and trucks are well over 1000 hp and some into the multiple thousands of hp, very capable engine design with enough $$ to throw at it.
kas83
Plover, WI
Would it be possible to put a DT466 into one of our trucks?
Yes it is possible, it has been doen a couple times in full blown pulling trucks. They are large motors tho, alot bigger than most swap candidates.
These motors respond just as well to minor mods as a 12 valve P-pump Cummins. Simple little things yield massive amounts of power and torque.
02AutoWag
Vacaville, CA
Are these DT engine easy to come by? No, I'm not looking for myself, but thought to post this for sale ad just in case someone was looking to try it. I don't know the going rate for one of these engines either, so no opinion on pricing from me...
http://sacramento.craigslist.org/pts/1463884867.html
parting out 3 S1900 85-86 with dt466 engines 210hp/dana cm-6052-c trans
1 S1700 1986 with 9.0L engine/allison 653 trans
1 cargostar 1950 1978 with dt466 210hp/allison 653 trans
most have 200,000 miles but they are well maintained state vehicals,some have maintance records
asking 800$for engine/trans combo or 500$ ea. other parts available
EricW
my $h!t is stuff
Middleton, ID
I actually know where that's at, too bad it wasn't available when i was down there...
