does gasser trans case = diesel trans case
Status
Not open for further replies.
bugman40284
Folsom CA
So I recently purchased a 1990 d350 with a bad transmission. I figured the packs were probably bad, but when I tore the tranny apart I found that the case was broken on the inside ring. My guess is someone dropped it into gear or they were towing something really freaking heavy. So is a gasser transmission case the same as a diesel transmission case. I am 90 percent sure that it is a A518 tranny.
ALSO: What am I suppose to call this transmission. I've seen 46re, 46rh, A518, 747, P4465OS........ what is the most common designation?
I put this post in the wrong section how the hell do you delete one of your own messages?
Status
Cv axle
