Some of the older guys might remember when I had my governor cover off in 2004 on a run of crappy IPs I had been getting. I had gotten a new governor cover. A bent inkage caused it to take off at full fuel when I started it. It was terrifying and brought the neighbors over. I stuffed a beach towel in the intake, no effect, pulled the fuel shutoff solenoid...no effect. I finally got it shutdown by cutting the fuel lines. The rpm was high but it may not have been much above governed RPM. It was enough fuel that it was more black smoke than I have ever seen anywhere and baked soot onto my dad's truck that was sitting next to it at the time. I was sure I had killed it, but it restarted just fine with the old poorly functioning (I had thought) governor cover reinstalled. One thing is for sure, it is a scary situation and hard to stick around and think rationally while it's happening. That engine is still in my truck and running reasonably well 7.5 years and 60,000+ miles later. I think the main difference between this and the catastrophic outcomes outlined in this post is that it never ran away on oil or crankcase vapors it just got jammed to full fuel. It is a recognized issue with messing with the governor or internals of the pump. I'm now always prepared when installing a new pump or if the current one has had anything critical messed with. If it's just fuel cutting off the air or fuel supply will kill it, maybe not if the crankcase oil and vapors or other gas vapors are involved. I was an example of knowing just enough to be dangerous.
