From what I've seen and heard, GM cast the problem areas either .020" or .030" thicker on the later 6.2 (1 piece rear seal) blocks and the 6.5 blocks. On the n/a applications, this took care of the problems. When you use the turbo engines hard, like pulling heavy loads, they would crack easier. Then in 1997 (I think) they put piston cooling jets in the blocks and gave them another place to crack. I've seen that.
