93turbo_animal
pun intended but I heard some growling from the brakes so I opened it up and found one pad was clear down to the metal and the rotors were all cracked with a couple pretty big cracks that went all the way thru the rotor The brake pads also had some cracks and I'm just wondering if the one pad didn't fail and the material all broke off since it was all gone while the rest were probably still 50%. Everything seems to work fine on that side so nothing seems to be sticking but I'll keep an eye on them for a while to make sure I don't have any other issues. I was also reminded why I hate working on my own equipment caues it seems once you start you just keep finding more and more that need replaced but while I was working on the brakes I noticed my one ball joint on the tie rod end is almost completely gone so now that I can stop again I'm working on the steering
