Detroit 6V92TA
Chevyboy_0
Mr.SunnyDisposition
Livermore, Ca
Hey ya'll,
I found a Detroit 6V92TA on CL here locally, the motor looks to be in pretty good shape and the guy is asking $1,000 for it. I was thinking this would be a cool swap in to my F-250. I mean a lot of people are going Cummins, so I think a Detroit would be cool. If I do move along with this is there anything I should know about the 6V92TA? As well as how hard are parts to find?
Thanks
The Warden
MiB Impersonator
Fog Bless Pacifica (CA)
I don't think parts are too hard to find at truck shops, although I'm not sure...2-stroke Detroits used to be VERY common, but they're getting older and more rare because of it...
As to getting it in your F-250...I'm not going to say that it's impossible, but a 6V-92 is not exactly a small engine. It was a common engine in full-size transit buses and would also be suitable for a semi. It's CERTAINLY bigger than a 6BT Cummins or a DT360, and I'm pretty sure it's considerably larger than a DT466. Again, I'm not saying that it can't be done, but you've got your work cut out for you...I imagine you'd need a body lift or to eliminate the hood just for the engine, let alone a tranny that'll handle the torque.
FWIW there are some videos floating around YouTube of a GMC pickup with a 4-53T swapped in. I'm attaching a pic I found a while back of a Ford engine bay with a 6-71 shoved in...granted the 6V-92's not as long as an inline 6-71, but it's wider and physically larger...
I've got a 8V71 and a V730 Allison, but the Detroit is a left hand slant engine. You could put it in the bed, total weight is only 5400#. Which would you prefer, the cable or air shift. Top RPM is only 2100, but lots of power with a 4:10 rear. The tranny alone weighs 1100, so the engine weighs 4300, but you could take the 360 amp alternator and air compressor off, that would prolly reduce the weight to 5000#. Then there is the radiator, one hugh SOB. :rotflmao:rotflmao
That 6V92 also takes that hugh SOB radiator, but it would look neet pushing that down the road.
Freight_Train
Traitor to the brotherhood
Gadsden,Al
You could beef up the front end,install a short bed,move the cab back,Cut and weld extention pannels in the fenders.........That might actually work.....or instead of cutting up the front end you could do all that and install a flip front hood from a big ford....or just buy a tractor and put your cab and bed on it...
Freight_Train
Gadsden,Al
here are a few vids to drool over....The white Chevy is forsale...10 grand.Tennessee Craigslist....Can't remember which.....
http://www.youtube.com/watch?v=K3yohoCqD2E
http://www.youtube.com/watch?v=vQXZSgDN9uA
http://www.youtube.com/watch?v=V6m2FLQSeJQ
http://www.youtube.com/watch?v=pPyp9dgHkw0
http://www.youtube.com/watch?v=EnN1i9LjAw0
http://www.youtube.com/watch?v=VkZjr0IJwtg
http://www.youtube.com/watch?v=VzlNm9V9TCM&feature=channel
http://www.youtube.com/watch?v=LEsOjMFcgyg&feature=channel
http://www.youtube.com/watch?v=OHcmdPsvEFw&feature=channel
http://www.youtube.com/watch?v=jUYrZB9_XCY&feature=channel
http://www.youtube.com/watch?v=_FZN_9Le7oQ&feature=channel
http://www.youtube.com/watch?v=EvzEqmNpo3E&feature=related
http://www.youtube.com/watch?v=ni8_e74yfVU
The following have wirty dords to be warned.....Why does the IQ of a lot of Youtubers drop to below 70 when they are making videos?
http://www.youtube.com/watch?v=5IQTKv_kneg&feature=channel
http://www.youtube.com/watch?v=txCW1ogM2C0&feature=channel
http://www.youtube.com/watch?v=oFId0UeAQTA&feature=channel
http://www.youtube.com/watch?v=qQLLzLJddZI&feature=channel
http://www.youtube.com/watch?v=1r2U7LkXFJ8&feature=channel
Ok.Done with the blabbering idiots.....back to G rated....
http://www.youtube.com/watch?v=7368eCCwr6A&feature=channel
http://www.youtube.com/watch?v=BbDY3GwjrO0&feature=related
Now option B is a 4-53 detroit....
http://www.youtube.com/watch?v=rhVnqOTlTxQ
http://www.youtube.com/watch?v=cNZlWwlSLqg
http://www.youtube.com/watch?v=0JnwMNcSbX4
http://www.youtube.com/watch?v=2aANhxdnIN0
http://www.youtube.com/watch?v=w0OLfOSSeuI
http://www.youtube.com/watch?v=5OTkaG9vjHc
http://www.youtube.com/watch?v=G98PQLyrILA
http://www.youtube.com/watch?v=vCx_uRPZNJM
http://www.youtube.com/watch?v=erDFz0oPlU4
http://www.youtube.com/watch?v=xZAVmsARKpU&feature=related
http://www.youtube.com/watch?v=tGzUb2Rpges
http://www.youtube.com/watch?v=dt0qUzpjrrE
http://www.youtube.com/watch?v=_UaJEPs0DJk
http://www.youtube.com/watch?v=EzV8okCULDg
http://www.youtube.com/watch?v=6IKPecdbis0&feature=related
http://www.youtube.com/watch?v=OG9KIgxbIuw&feature=related
http://www.youtube.com/watch?v=AExLA93hOyg&feature=related
http://www.youtube.com/watch?v=p8-Kre-RGKs&feature=related
http://www.youtube.com/watch?v=J5jBPJh2fK8&feature=related
http://www.youtube.com/watch?v=K2zwd1iazvU&feature=related
http://www.youtube.com/watch?v=je0LHKp51u0&feature=related
http://www.youtube.com/watch?v=Z_tM7yz5_PA&feature=related
http://www.youtube.com/watch?v=uZWgrTde348&feature=related
http://www.youtube.com/watch?v=E0o1o5W_f6o&feature=related
http://www.youtube.com/watch?v=mP4_ZukfL4Y&feature=related
http://www.youtube.com/watch?v=6BuDby-831I&feature=related
http://www.youtube.com/watch?v=T5V44xmPwMU&feature=related
http://www.youtube.com/watch?v=yd-P9TGMmyU&feature=related
http://www.youtube.com/watch?v=aLM6fvUbWLM&feature=related
http://www.youtube.com/watch?v=LKUMuqK5KF4&feature=related
Now some clips of the original engine of this post......just for teasers....
http://www.youtube.com/watch?v=IWNgzvkB2qs
http://www.youtube.com/watch?v=dVjXwS8HzFw
http://www.youtube.com/watch?v=x1YXx4kytNU&feature=related
http://www.youtube.com/watch?v=xWkHuPgkLps&feature=related
http://www.youtube.com/watch?v=DFGKIjtmsNo
http://www.youtube.com/watch?v=aojCHMju8bs&feature=related
http://www.youtube.com/watch?v=N5QPHebHzHk&feature=related
http://www.youtube.com/watch?v=M63_a5f8p60
http://www.youtube.com/watch?v=jESFUMqy9Tc
http://www.youtube.com/watch?v=M1zPi45oCcY
Freight_Train
Gadsden,Al
you could shoehorn the 3208 in there I think.Then you had the itty bitty 1.1L but don't get in any kinda hurry.
snicklas
6.0 and Loving It!!
Staff member
Greenfield, Indiana
I know that in the late 70's that Cat, through their authorized dealers, McAllister here in Indy was one of them. You could bring in you pickup, I knew someone that saw a 79' F-350. Cat offered a conversion kit, the dealer removed the gas powerplant from the truck and replaced it with a 3208 Cat. Not sure if it was NA or Turbo. They were one pulling monster at that point.....
Cv axle
