decked block/heads affect pushrod length?
bj_idi
SFL
had the block decked 8 thou and the head between 4-6 iirc is that going to affect my push rod length or is stock going to be ok? will the lifters compensate for the extra length on the pushrod now
also had piston face cut .010
Hydro-idi
Lodi, California
The lifters should compensate if you decked the block & heads within factory specs.
If you took more material off than what was recommended, you might have some issues, especially fitting that intake manifold on engine.
bj_idi
SFL
Thanks! exactly I am almost there will see about the intake manifold shortly
I'd think that you should be ok since you had .010 removed from your pistons too.
bj_idi
SFL
yea should be all good there was 26 out when I checked it, my thought was that the push rod being stock length, maybe it would hold the valve open slightly? i like what I'm hearing that it will compensate
