zrexryder
Does any of these thing exist for the IDI?
I was just trying to find out if there was a way to run it with no electrical means. Maybe just a BIG hand crank like the old willys
I found an on-line copy of a Stanadyne DB-2 pump manual a while back, and it definitely referenced a cable-type shutdown option for some pumps used on other applications.
Not sure how widely they're found or where you might get one, or how readily that sub-assembly would go on a pump without digging too deep into the delicate parts.
Bolt a spacer onto the outside of a rear wheel and bolt a second tire-less wheel onto that spacer.
Raise that wheel clear of the ground.
Wrap several turns of a rope around the empty wheel.
With transmission in direct, and fuel and key ON, jerk the rope.
If you don't have enough strength to pull the rope quick enough, hook it to a double-tree, give the mules a slap, and stand back.
I have heard some discussion about a manual fuel shutoff but not of the air starter.... Sounds like your thinking ahead for a dooms day machine.... Al these idi motors really need to run is a manual fuel shutoff valve... Then a down hill bump start gets them running without any electrical needs....
WOW!!! They had winches for recovery way back when that were pretty close to what you described.
