F350farmboy
The Hornet
I've been looking at a truck at a heavy equipment dealer for my 4x4 donor...but unless it has the same gears as mine...its probably not going to work out (dad's not too fond of the idea of re-gearing...). The main reason for this truck was because it has everything on it I would need...tranny/t-case/D60 and all brackets/etc. I would also use the donor to mark and drill holes for the hangers and such.
If the truck doesnt happen, I have an '89 F-250 4x4 with the TTB front axle. Are the hangers, brackets, etc in the same locations as the ones off an F-350 D60? Because if they are, I could get away with just buying the parts and still use the '89 for measurements.
Is this feasible?
Thanks
On Edit: And I would like to buy a divorced np 205 if I have to piece out the swap parts...So I dont have to buy another tranny. Would I be able to use one on the '85??? Thanks
Is this feasible?
Thanks
